Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - EGR Valve Removal
Old 03-05-2013, 01:34 AM   #6
xsuicidesn0wmanx
xsuicidesn0wmanx's Avatar
Fan#: 65239
What I Drive: 2001 Black Ford Focus SE Sedan
Points 566, Level 11
Points: 566, Level: 11 Points: 566, Level: 11 Points: 566, Level: 11
Level Up 32% Completed
FF Reputation: 1 xsuicidesn0wmanx Good Standing Member
Did some reading up on this and found that the sulfur smell is from unburnt fuel getting to the cat, when I hook up the vacuum hose to the top of the egr valve the car has a bad stutter/rough idle, while observing the reaction of the engine while everything was hooked up i thought it sounded like it was misfiring, i'd bet that would explain why i smelt sulfur.
It however does not explain why the system still does not work, brand new motorcraft valve, and a new dpfe sensor, only thing not new is the actuator.
I'm considering seeing if i can get the dpfe workaround #2 from focushacks to work so i can pass this stupid emissions garbage.
xsuicidesn0wmanx is offline
