Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dogbone install issues need help ASAP
Old 03-04-2013, 10:18 PM   #17
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2004 highly modded Mini Cooper S
Points 7,547, Level 57
Points: 7,547, Level: 57 Points: 7,547, Level: 57 Points: 7,547, Level: 57
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 24 freemind Great Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by zetecDon View Post
Put your car on either jackstands or ramps. Take your jack with a block of wood on the lip and place that under your car. Raise the jack until it is supporting the motor. Loosen up the passenger side motor mount but don't take the bolts all the way out. This will give you a bit more of swaying motion in the motor. You may need someone to hold the engine while you place the dogbone mount into position. After you get the mount into position put the bolt in there and then tight the passenger mount back down.
^This
133whp-126ftlbsTQ Eclipse CD8443,Eclipse PA5422, JBL GTO751EZ, PPI 356cs(Rebranded A/D/S 346cs), JBL p1024, SubThump enclosure, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
