Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus Won't Start
Old 03-04-2013, 09:17 PM   #35
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 544, Level 10
Points: 544, Level: 10 Points: 544, Level: 10 Points: 544, Level: 10
Level Up 88% Completed
Forum Activity 13%
Activity: 13% Activity: 13% Activity: 13%
FF Reputation: 25 Milton Great Standing Member
2001 Ford Focus Starting Diagrams
Originally Posted by Red01Focus View Post
... 2001 Automatic Zetec Sedan...
ok did the baking soda/water trick scrubbed it all down cables look better,went to get the battery had it tested and printout showed the battery was good,installed it and yep nothing..i think the clicking is the door chime that doesn't have enough power to actually sound. so replace cables?
Well that's a bummer. You'll have to find where the issue is. Here a a link to you 2001 Ford Focus Starting Diagram:
Print out the diagram for your 2001 Zetec ATX, grab your volt meter and start checking. Start at the battery and work your way out from there. Personally I would start by checking to see if you're getting 12v to your starter. If you are not then next check the fuses. If they are good then start at the battery and then work your way out from there.
Good luck.
Milton is offline
