Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fumoto Valve for blower drain?
Old 03-04-2013, 05:58 PM   #1
redwake
redwake's Avatar
Fan#: 100718
What I Drive: 00 Black ZTS
Points 1,028, Level 17
Points: 1,028, Level: 17 Points: 1,028, Level: 17 Points: 1,028, Level: 17
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: 3 redwake Good Standing Member
http://www.qwikvalve.com/fumoto-f106n-valve.html
^ for oil return.. can you think of a reason i can't run this oldie but goodie? assuming my drain is 3/8"? (need to measure it when i get home)
i was thinking i could just put one of these on and leave it in the open position? then when its time for an oil change i could close it, unhook the hose and open back up or even remove it completley so there isn't any oil left in the pan. goal is to save dropping, threading, and re-sealing.
yay or nay?
I'm about 2 months out from installing the stage 2 VF/FS SC. This will save some more time. also trying to make the return to stock process as simple as possible for CA smog reasons.
MK1 ZTS w/Lentec ATX - More economical than a Prius
2" drop - projectors - boost by vortech - tune by fswerks
My Car: http://tinyurl.com/8mpden8
Sr# 256.
redwake is offline
