Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wire conduit heating up and coming off
Old 03-04-2013, 05:02 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,102, Level 100
Points: 33,102, Level: 100 Points: 33,102, Level: 100 Points: 33,102, Level: 100
Forum Activity 69%
Activity: 69% Activity: 69% Activity: 69%
That wiring is set up on clips, so that's where it should be. You could wrap it with some insulating tape. I would use a roll of what's called "friction" tape from the electrical dept in a hardware store. It's basically cloth tape with a substance on it that grips. On older cars, this was used as wiring loom. If you use it, you must be sure that each wrap is halfway over the top of the previous wrap. It can't be loose when installed, but it doesn't have to be pulled tight either- it must be snug.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
