Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - brake question
Thread: brake question
Old 03-03-2013, 10:51 PM   #3
brekkebooboo
brekkebooboo's Avatar
Fan#: 109524
What I Drive: 2007 with svt front & rear end
Points 1,508, Level 22
Points: 1,508, Level: 22 Points: 1,508, Level: 22 Points: 1,508, Level: 22
Level Up 8% Completed
Level up: 8% Level up: 8% Level up: 8%
FF Reputation: 1 brekkebooboo Good Standing Member
Originally Posted by whimsicalpouch2 View Post
you can always go ebc redstuff or green stuff, hawk pads are another option, both are great performance wise with some solid bite to it.
for rotors you can go drilled/slotted and drilled/just slotted if you don't want a normal rotor.
pads are more important when it comes to stopping than the discs, you need that hard bite on the rotor which comes from the pads.
also make sure your calipers are working properly and lubed up.
stainless steel brakelines will also help out alot
I was leaning towards the stop tech slotted rotors from fswerks. the hawk hp plus pads will do me good??? Their like 30 bucks cheaper then the other hawk pads I found on there site.
Sent from my Glade air freshener using Banana
brekkebooboo is offline
