Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Pressure concern/question
Old 03-03-2013, 06:31 AM   #4
shineboy
shineboy's Avatar
Fan#: 60173
What I Drive: 2013 ST, 2004 Cobra
Points 1,469, Level 21
Points: 1,469, Level: 21 Points: 1,469, Level: 21 Points: 1,469, Level: 21
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
FF Reputation: 1 shineboy Good Standing Member
Originally Posted by thejordan View Post
high pressure at cold is normal.
normal warm operating pressure is 29-60psi.
warm idle should be around 15-20psi.
it will obviously vary while driving in addition to turbo usage.
i think you can put the st into test mode and read the actual pressure from obd2.
How do you put it in obu test mode. I remember holding the odometer reset on my old SVTF to get to some sort of diagnostic. I also have a SCT tuner, I will see if that can see oil pressure.
My actual concern is I just had the dealer do their complimentary service, prior I am pretty sure the numbers were higher. Wondering if they out 5w20 in itů
2013 ST2 for DD
2004 Terminator for fun
shineboy is offline
