Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Having aftermarket headlight problems?
Old 03-02-2013, 11:02 PM   #4
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 1,054, Level 17
Points: 1,054, Level: 17 Points: 1,054, Level: 17 Points: 1,054, Level: 17
Level Up 54% Completed
FF Reputation: 4 gtferrari Good Standing Member
Factory harness works as it should. Plugging the original h13 bulbs in works. With the h13 when high is on low is off. This is to darken the area immediately in fron of the car forcing your eyes to focus farther up the road where the highs are aiming.
Ive tested and i have 12volts where i should and good grounds with no resistance (not open or ol).
There was a wierd thing on the harness about half the size of a resistor or a diode but un labeled and only had one lead. I believe it was on the ground circuit. It must have feed back to the low side power circuit but rusted away.
Most likely i will end up having to replace the harness and relays as i doubt there is any warranty on them
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
