Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SPI Hiccup
Thread: SPI Hiccup
Old 03-02-2013, 09:42 PM   #2
dromeda
Fan#: 28157
Points 155, Level 3
Points: 155, Level: 3 Points: 155, Level: 3 Points: 155, Level: 3
Level Up 10% Completed
FF Reputation: 1 dromeda Good Standing Member
Mine's done this twice:
1) Every now and then it would shimmy then stop until it always did it and it turned out to be a vacuum leak on the PCV hose (from the intake tube rubbing on it).
2) Spark plugs needed changed. There was no electrode/insulation left and it was arcing inside the plug (or not at all) causing misfires.
Since you said highway, I'm guessing it's a misfire issue. Have you tried pulling any codes? Misfires can happen three ways: no spark, no fuel, no air. When was the last time you pulled the plugs? Any misfire or lean codes?
dromeda is offline
