Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Lock Switch Lights (SVT)
Old 03-02-2013, 01:14 AM   #82
SVT_DAEMON
Fan#: 57618
What I Drive: 2004 SVT EAP Focus
FF Reputation: 1 SVT_DAEMON Good Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by Rudel View Post
Tools you will need:
  1. Solder Iron
  2. Solder
  3. Pliers
  4. Wire Stripper
  5. 16-18 Gauge Wire (Threaded)
  6. 1/4 Wratchet
  7. 1/4 Wratchet Extention
  8. T-20 Torx Bit
  9. Power Source Detector (Clear Orange Thing)
  10. Zip Ties
Begin by using the 1/4 wratchet with the extention and T-20 torx bit and unscrew the bolt that is holding the door handle, lock, and switches.
Once that is done, pull on the face plate until it comes off. It may take some M.A.N.
Now take about 4 peices of wire, 8in each, and strip the ends about 1/4" inch, and start to twist the threaded end.
Now tin the ends of them so they will not bird-cage on you when they are pushed into the socket terminals.
For the following instructions there is no need to do any more soldering, all you have to do us snug the wire into the back of the sockets with the other wire(s). After that zip tie them so they are not all dangling around.......
On the back of the socket for the window switch do the following:
Put the ground (blue) wire into socket 1, with the Black Wire
NOTE: Passenger side is socket 4, with the Black Wire
Put the Hot (red) wire into socket 10, with the Blue/Green Wire
NOTE: Passenger side is socket 2, with the White/Green Wire
On the back of the socket for the lock switches do the following:
Put the ground (blue) wire into socket 4, which is the LED Ground.
Put the Hot (red) wire into socket 5, which is the LED 12V Supply.
And the outcome!
Here is a diagram incase you need more reference:
Anyway to get the pics again? Would like to try this. thanks
SVT_DAEMON is offline
