Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installing coilovers this weekend. couple quick questions.
Old 02-28-2013, 07:28 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Buy-Sell-Trade Rating: (3)
Hi guy, 2005.5 is when it switched, check what month the car was manufactured, if you do this is the kit you'll need http://massivespeedsystem.com/_massi.../i-252473.aspx
#2 what size tire do you have? Because the factory size tire I had didn't rub but was low with out rubbing everything in the world
#3 and like I told you when we traded put some oil or antiseze on the part that you put into the front knuckle, the rear is going to be a b##ch unless you want to replace the lower control arms because the bushing get seized take the sway bar links off and out of the way I would probably replace the links unless you have before then take the the two bolts off that are on the part of the main control blade for the suspension
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
