Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MK3 2012 Focus - Oil Change 101
Old 02-28-2013, 01:35 AM   #255
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by BlueFocusSE5 View Post
Again, when the oil system loses it's prime when an oil change is done the resulting engine start has zero oil pressure, allowing metal-to-metal wear to occur. This is why some people take the care of priming the new oil filter, to try and lessen the damaging effects of a no oil pressure/dry start situation, which is very wise. If this wasn't an issue, people wouldn't bother to prime the oil filter.
Yes priming the oil filter can prevent initial/temporary rod knock. That didn't seem to be what you were saying initially. Saying oil changes themselves are more damaging is a bit of a misnomer. Poor oil itself the biggest damage to an engine especially if not filtered properly or if it loses viscosity. The damage from a proper oil change versus a cold start will be negligible.
thejordan is offline
