Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Revo Knuckle suspension on the ST?
Old 02-26-2013, 08:44 PM   #7
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: MK III
Points 189, Level 3
Points: 189, Level: 3 Points: 189, Level: 3 Points: 189, Level: 3
Level Up 78% Completed
FF Reputation: 6 jsr72 Good Standing Member
Originally Posted by apagios View Post
I would suspect to even try putting a RevoKnuckle on an ST you would have to order spare parts from Europe. Assuming you could get the Revoknuckles ordered, here's a first blush guess at what you'd have to confirm before trying it.
Compare everything that attaches to the wheel knuckle:
- Axle length
- wheel bearings
- Tie rods & ends, length fittings
- Brake caliper mounting points
- Macpherson strut mount point
- Ball joint mount
Flared fenders for the wider track, different swaybar, bigger rotors...
Assuming all that, the Revoknuckle would now compensate for torque steer. But the Focus ESC automatically uses small brake applications to counter the "feel" of torque steer. So now this system would be over compensating for the forces involved in torque steer.
ESC uses braking for yaw stability. The ST uses the electric steering system to provide additional steering assist to help compensate for the steering torque felt by the driver.
Revo knuckles do not eliminate torque steer - they help reduce it in the same way a double wishbone does. Left-right asymmetries will always be present in the chassis.
jsr72 is online now
