Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Injection Molded Center Console Tray WITH Change Holder Thread (MK3 Focus)
Old 02-26-2013, 08:11 PM   #58
Pinion Dominion
Pinion Dominion's Avatar
Fan#: 105589
What I Drive: 2012 White Platinum Focus Titanium
FF Reputation: 4 Pinion Dominion Good Standing Member
Is this what you mean?
Originally Posted by I Bleed Ford Blue View Post
After looking at your test unit I like it better than the factory one. You mentioned the possibility of having provisions to remove entire corner if needed. I would rather see a knockout for a U shaped notch about .25" wide and about .5" deep. I would still take one as is, I can always dremel out a notch if needed. Since my car is a Ti with black leather interior, either dark gray or black is fine by me.
An example of what I mean when I say the corner can be "removed". This will be permanent. There will be guide lines on the bottom face of the tray and you use a knife to cut it. (Maybe it can be snapped out, I'll have to check with the supplier.)
Zoomed In:
(Please use this as reference only, final cut-out will look nicer, just a concept.)
If interested I'd prefer either black to match the usb/ media panel or a tan color to match the interior of the car, but that wasn't listed.
It does seem to completely cover the USB/ aux cable ports though.
Pinion Dominion is offline
