Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Best headlight / HID options for poor headlights on 2007 Focus?
Old 02-25-2013, 10:15 PM   #16
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,454, Level 100
Points: 32,454, Level: 100 Points: 32,454, Level: 100 Points: 32,454, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
You have an electrical problem- most likely in grounding, but could be on the hot side as well. The first thing I'd check is the grounding. Look at the ground wires on the battery terminal- remove the ones that attach to the stud with rings. I bet one of those rings is broken. If it's not there, then it's probably on the hot side.
Silverstars are marketing, and the lamp burns up much quicker than standard halogen lamps. Just get your some Sylvanias made for the car. I bet if you measured voltage in the socket, you'd get 10v.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
