Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 08 s Projection HID problems
Old 02-25-2013, 02:19 PM   #10
blade08
blade08's Avatar
Fan#: 104798
What I Drive: 2008 Silver Focus SE Sedan
Points 308, Level 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Level Up 16% Completed
FF Reputation: 1 blade08 Good Standing Member
Originally Posted by tucls View Post
If the H13 bulb is a dual filament bulb creating the high and low beam physically it may fit but the reflective plate inside will give you problems. If it's down then your high beam will get cut off and rendered useless. If it's single it might and you might be able to try it but I would consult someone who deals with HID on a regular basis. Just keep in mind the moving reflective plate inside. I'm currently in the process of trying to get my money back. When my set was wired in the housing there were electrical problems the mechanism controlling the plate was fried on both lights and I can't fix them.
keeps me posted about your lights.
Ah I see. Well I got a cheap Hid kit from eBay. Was dealing with flickering, lights going out so I got a relay. That helped...for a day. As soon as I got home one of the bulbs wouldn't turn on. The customer service has been good so far but I'm thinking I'm just going to return the kit and get some ddms. It was a 55watt 6k
My headlights themselves seem to be great. I bought these off of nickster in the forums and he didn't experience much or any problems to my knowledge.
Sent from my LG-P999 using FF Mobile
blade08 is offline
