Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED lights
Thread: LED lights
Old 02-24-2013, 03:10 PM   #8
blade08
blade08's Avatar
Fan#: 104798
What I Drive: 2008 Silver Focus SE Sedan
Points 308, Level 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Level Up 16% Completed
FF Reputation: 1 blade08 Good Standing Member
Originally Posted by CREWZIN View Post
Added a strip of LED's to the front since the 11 Focus didn't come with DRL's.
That looks clean!
Are your license plate lights still running well?
Originally Posted by 2011 SE View Post
I agree with the above post except for the bit about the license plate lights. I've converted my dome/map/license plate lights to LEDs with no problems. The only thing you need to worry about is the fact that the license plate bulbs actually run at just over 14v, not 12v. This means that they will quickly destroy any 12v LEDs you put back there. My suggestion, as you will find elsewhere, is to use a set from 42draftdesigns. They make the license plate bulbs that can handle the voltage.
I bought a set from SuperBrightLEDs.com and they lasted about 4 weeks. The set I bought from 42draftdesigns is going on 6 months with no problems at all.
Pictures:
There is also a thread somewhere that goes over the install. If you can find it, I added a bunch of pictures and a semi-walkthrough.
Are the led license plate bulbs still running?
Sent from my LG-P999 using FF Mobile
blade08 is offline
