Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Murray's new SPI build
Old 02-24-2013, 03:10 AM   #39
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
Points 45,306, Level 100
Points: 45,306, Level: 100 Points: 45,306, Level: 100 Points: 45,306, Level: 100
FF Reputation: 13 TheGlassMaker Great Standing Member
Buy-Sell-Trade Rating: (5)
You should always replace the head bolts. Head bolts can and will stretch over time due to the fact they are usually steel and the head is aluminum, as the two materials have different thermal rates.
If you reuse the old bolt it could break, or it could bottom out in the threaded hole of the engine block causing damage to the block and/or not tightening down the head all the way.
For safety reasons head bolts should only be used once.
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is offline
