Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - what do i need for cams
Old 02-23-2013, 09:15 PM   #4
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 89 Civic Base
Points 13,492, Level 75
Points: 13,492, Level: 75 Points: 13,492, Level: 75 Points: 13,492, Level: 75
Level Up 61% Completed
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I'd certainly do a header and tune before the cams. Regardless is you like Tom or not, he does provide free NA upgrade tunes so once you do the cams you can have him retune it.
As far as doing the cams though, aftermarket gears aren't required, but can be beneficial to get the most out of the camshafts. You should also consider aftermarket valve springs if you are going to be revving high. Also you will need a set of feeler gauges to measure the clearance between the cam lobes and buckets and if any are out of spec with the new cams, the bucket will need to be replaced with one of the correct thickness.
Of course this last part people often skip. Often works out ok but if it were my car i'd want to know for sure it was done correctly.
jetrinka is offline
