Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Long Crank/Hard Start 2.0L And 2.3L Engine With MTX-75 Transaxle Bulletin
Old 02-23-2013, 03:00 AM   #109
Z3T3C
Fan#: 107116
What I Drive: 2000 SE Zetec with ATX
Points 134, Level 2
Points: 134, Level: 2 Points: 134, Level: 2 Points: 134, Level: 2
Level Up 68% Completed
FF Reputation: 1 Z3T3C Good Standing Member
I have a 2.0L Zetec in my 2000, and won't claim to know anything about the newer focuses or duratec engine's. However, I had a similar problem in my car. I had codes for other issues that I took care, but then still had hard starts. Sometimes then engine would stutter and occasionally it would die. I even started a thread and was told it probably wasn't a fuel problem as I thought it may have been. But it did end up being fuel related. It was resolved once I changed the fuel pressure sensor that is bolted into the end of the fuel rail. That is my 2 cents for anyone that is still having issues after the PCM update, a new or clean functioning IAC valve, new spark plugs, good coil, and ground contact points cleaned and redone.
Z3T3C is offline
