Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus ST break in
Old 02-22-2013, 12:27 PM   #7
Matasickle
Matasickle's Avatar
Fan#: 77627
What I Drive: MK3 SGM SE
Points 2,726, Level 31
Points: 2,726, Level: 31 Points: 2,726, Level: 31 Points: 2,726, Level: 31
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 2 Matasickle Good Standing Member
Originally Posted by lddavis View Post
According to the owner's manual (including the ST supplement), no break-in period is required.
I find it hard to break old habits, so despite the manual, for the first 1000 miles, I do the normal break-in thing:
- vary the RPM (not necessarily "speed"; if you're on the highway, move between upper gears occasionally to vary RPM even if you're stuck at 65 mph)
- avoid high RPM at first (hard as that is with an ST :)) and only gradually increase the upper bound
- make sure the engine sees at least some instances of high pressure (open throttle in a higher gear will do this without necessarily causing a lot of acceleration, RPM, or speed)
- make sure to decelerate under vacuum as well (leave the car in gear and take your foot off the gas when approaching a stop, etc).
Change the oil and filter after 1000 miles.
That was very informative.
I thank you, sir.
Matasickle is offline
