Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus 2012 +12V Ignition Help!!!
Old 02-22-2013, 12:18 AM   #17
tylerg2002
Fan#: 106623
What I Drive: 2012 Sterling Grey Metallic SE
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 1 tylerg2002 Good Standing Member
I'm pretty sure I connected the correct wires, and I did the reset >2/<10 secs. method several times thinking maybe it didn't connect properly. When I did the reset, the third and fifth green LED flashes were long, with the rest being short. The red LED flashed four times, which is correct for the Sony stereo I have. Am I correct in leaving the vehicle side of the gray/yellow wire disconnected, and only having the white/green wire spliced to the harness side of the gray/yellow wire? That part confused me some, but that's the way I took it.
I was puzzled when it turned the volume all the way up, and disabled the touch screen navigation of my stereo. When I touch an item on the screen, it highlights it but doesn't select it. I've never had a problem with the Sony before this, and I'm inclined to think it's something to do with the remote connection.
I will confirm my wiring and try again after work in the morning. I'm really excited to get this working. I've really missed my steering wheel controls these past few months.
tylerg2002 is offline
