Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any info on the Cosworth 2.3 280BHP Engine Swap?
Old 02-21-2013, 04:29 PM   #15
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
FF Reputation: 23 wrc_fan Great Standing Member
Originally Posted by OrangePeel View Post
I'll contact someone at the SCCA for a recommendation on which class to join specifically for my theoretical vehicle setup. I'll post back with detail on what I find. :)
By the way guys, thanks for helping me be thorough about this all. These are some of the questions I was hoping to receive.
SCCA Solo aka Autocross is not about power. Its about the driver, tires and suspension. Then maybe weight reduction, then power.
If you want to build an E Prepared car go for it, but you will not have a streetable ride. Street modified fwd would be the highest you can go IMO and have a streetable car.
To be competitive at street modified and above, you will need high dollar dampers (at least $2K) and need to make custom suspension links so you can run spherical bearings where ever possible.
Spring rates will be 600 inlbs + all around.
You'll need hoosiers as a minimum of course.
Then scrounge the rule book for every weights savings possible.
A limited slip differential is esential as well.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
