Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.3 stock cam specs anyone? In Factory Manual?
Old 02-21-2013, 12:01 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,502, Level 96
Points: 25,502, Level: 96 Points: 25,502, Level: 96 Points: 25,502, Level: 96
Level Up 16% Completed
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Originally Posted by bones33 View Post
Thanks Felix. I see what you mean, pretty mild.
Hey, would you happen to know when the intake begins to open BTDC, or closes ABDC?
No sorry, it doesn't even list it in the shop manual either. To give you a idea, the crane cams I have are= Int. opens -4 degrees atdc/ closes 36 degrees bbdc. Exh= opens 32 degrees bbdc & closes -8 degrees btdc. 4 degrees overlap= intake closes & exhaust opens. This is cranes #224-0010. I do like the next one= 224-0012. Int.= 226 @ .050/exh. 216 @ .050 w/ .410/.385 of lift. Int opens at 3 degrees atdc/ closes at 43 degrees bbdc. exh. opens at 38 degrees bbdc & closes at -2 degrees btdc. The cranes are on a 110 LS vs crowers which are on a 114 LS angle. All the 23 motors should of had cams similar to the cranes spec's to begin w/.
felixthecat is online now
