Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Spi question
Thread: Spi question
Old 02-21-2013, 06:24 AM   #7
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
I would change the belt at least.
As mentioned, you won't be able to tell if the seats were changed unless you pulled the head... and even then, unless you have the documentation, I would assume it hasn't been done.
And yes it does depend on the damage. it will destroy a single piston at least. I actually drove mine into the shop to pull the engine. Later, I pulled it apart and was shocked to see only about an inch in height of the piston left. Others have had a rod through the block. The other pistons might get some dings in them, but as long as the top ring still moves freely, it can be reused. The ring was smashed (compressed) into place on the damaged piston.
Mileage? that depends. greatly.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
