Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sound Upgrade Almost Done (Premium Really??)
Old 02-21-2013, 12:09 AM   #17
jfkaiser
Fan#: 110211
What I Drive: Focus ST Tangerine Scream
Points 458, Level 9
Points: 458, Level: 9 Points: 458, Level: 9 Points: 458, Level: 9
Level Up 16% Completed
FF Reputation: 1 jfkaiser Good Standing Member
Wiring Harness or cut the amp wires?
Hi Aaron,
Thanks for this info. I just pulled my MS8 out of a highly modified Toyota Prius installation and REALLY want to install it in my new Focus ST
I plan to keep the Sony stereo Head Unit
However, I can't bear the thought of cutting the wires at the amp
Question: Were you able to buy or construct a wiring harness that would let you tap into the Sony amps Front Lo and Front Hi and SUB speaker outputs or dd you have to cut the wires?
Question2: the Bluetooth "echo" problem that my callers always heard when I installed the MS8 in my Prius (used a Kenwood Aftermarket headunit in there)
always drove me crazy...........are YOUR callers experiencing the MS8 bluetooth echo issue with your install and your Sony Head Unit?
Thanks much for all your contributions to this forum!
Jon
jfkaiser is offline
