Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec MPG Advice
Old 02-20-2013, 12:00 PM   #10
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
What I Drive: 2003 2.0L Grabber Green Zx3
Points 26,907, Level 97
Points: 26,907, Level: 97 Points: 26,907, Level: 97 Points: 26,907, Level: 97
Level Up 56% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Originally Posted by tmittelstaedt View Post
OK your looking for MPG, let me tell you some facts, here.
1) You will never get the best MPG if your throttle is EVER at WOT. If your highway cruising, your throttle is barely cracked open. That means all the porting and suchlike does NOTHING. Porting makes no difference unless your at WOT. So do most of the go-fast stuff on the car does absolutely nothing.
2) For best MPG you want to have the car at the lowest RPM at all times. Meaning that when shifting you get the car up into the highest gear as quick as possible. And also meaning that you want the tallest gears possible. Your 3.90 axle ratio coupled with 14" wheels is a problem here. What does your RPM run at when your at 70Mph? I'd bet it's pretty high.
3) If your running a catcon, then you have very little choice in fuel mixture because while the engine will be perfectly happy running on a leaner mixture, you will burn up your catcon.
4) remove weight from the car. You said you drive for work - well do you haul passengers around and people? If not, remove your seats and put them in the garage.
5) lowering is good for MPG.
6) reduce speed. Sorry to say this but I'll give you the following challenge. For 1 tank of gas, do not drive faster than 55Mpg on the whole tank. Then check MPG.
7) Does your car have a trunk mounted spoiler bar? If so, remove it - those are MPG sucks. Spoilers work by pulling energy away from going forward and converting it to downward pressure.
8) fuel is wasted every time you apply the brakes. Be forward-looking and pull your foot off the throttle way, way, way in advance of an intersection and coast to the red light.
Agreed, I'm getting around the same mpgs with a mixed commute. People don't realize just how much more fuel they suck up when you start going past 55mph. It goes down dramatically, not alittle. The difference in fuel consumption between 55 or 60mph, compared to 70 is as much as 15-20% less mpg. If you fill up your tank and drive 70mph, you'll see the needle drop below the Full mark before you even hit 50 miles driven. But if you keep the speed down 60 or below, the needle will still be at the full mark.
Not sure what kind of roads you are driving on, maybe the speed limit is 65 or 70. If so go the slowest possible without pissing people off or becoming a danger on the road. But if its 55mph and you are just speeding, slow it down. You will see more MPG gains by far then any amount of mods will get you.
Getting the best out of your car is always about how you drive and keeping your car properly maintained.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
