Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Upgrade to leather ???
Old 02-20-2013, 09:16 AM   #7
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by trevor_shiggs View Post
I would check fuses 18 and 43 in the SJB to see if there are 2 pins where the fuses go or just 1. If there is only 1 It would mean alot more work and that the vehicle is not wired for heated seats.
Pins 33, 22, 27, and 16 on the drivers side seat connector are for the Heated seats,
Pins 23,14, 22, and 16 on the passenger side are for the heated seats.
I would start by checking to make sure the pins are present on the vehicle side of the connectors.
I find leather is way easier to clean, ever clean spilt coffee off leather? Just simply wipe it up, where as with cloth you may have to steam clean etc to get it out. My girlfriends 09 focus with cloth seats has already started to wear through the seat cover as where my leather ones only show slight wrinkles from how I sit. For the cold, I have heated seats not a big issue for me I usually wear pants in the winter. To each their own.
Well said good sir, I applaud you.
If you can't wear it out, burn it off
DarderSauce is offline
