Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No 4th gear
Thread: No 4th gear
Old 02-19-2013, 09:38 PM   #21
amc49
Fan#: 96610
Points 6,415, Level 52
Points: 6,415, Level: 52 Points: 6,415, Level: 52 Points: 6,415, Level: 52
Level Up 33% Completed
Level up: 33% Level up: 33% Level up: 33%
Forum Activity 100%
Luck...........you should probably know that Ford strongly recommends the trans cooler be changed when this type of wear occurs, often the cooler stops up and the return to back of the end cover then slows down to a trickle to wear the cover out. The cooler is supposedly not cleanable, the design of the inside of tubes stops it from flushing clean of trash settled in it.
amc49 is offline
