Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Updated clutch?
Thread: Updated clutch?
Old 02-19-2013, 09:06 PM   #15
rrodda
Fan#: 91025
What I Drive: 2012 silver Focus
Points 136, Level 2
Points: 136, Level: 2 Points: 136, Level: 2 Points: 136, Level: 2
Level Up 72% Completed
FF Reputation: 1 rrodda Good Standing Member
Originally Posted by noahsfocus View Post
Please give us the part# for the clutch pack when you get your invoice. And ask them for more detail on why they replaced it. Thanks!
Here it is:
Road tested and confirmed the trans slips going into 2nd and 4th gears. Tested for codes and found no codes. Inspected the fluid and found full but also that the trans is leaking from the bellhousing area. Removed the trans and replaced both input seals and the clutch assembly. Reset the trans adaptive strat. Road tested and found OK
And the part numbers:
1 BV6Z*7B546*B clutch assembly
2 AE8Z*1S177*A seal
1 AE8Z*7048*A seal asy--oil
1 AE8Z*7052*A seal asy--oil
1 YS4Z*3N324*AA retainer--bearing
plus 8 nuts total and trans fluid
On the short drive home it seemed fine, way smoother than the SEL rental, also a 2012 with almost the same mileage as mine. The powertrain control module was also reprogrammed.
rrodda is offline
