Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus SE
Thread: 2012 Focus SE
Old 02-19-2013, 02:01 PM   #14
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,800, Level 71
Points: 11,800, Level: 71 Points: 11,800, Level: 71 Points: 11,800, Level: 71
Level Up 38% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
I've begun audio system upgrades.
The battery-top fuse holder from my old car wouldn't fit nicely on under the battery box on the 2012, so I found a plain black plastic fuse holder on Amazon (coincidentally, Littelfuse is located next door to the building I work in).
Littelfuse 298900 ($12.76 on Amazon)
20130218_30D_IMG_0036 by mellephants, on Flickr
20130218_30D_IMG_0037 by mellephants, on Flickr
After reviewing the photos, I noticed the ring terminal on the left isn't seated nicely, so I went out and fixed it. I didn't re-take the pictures, though, because it was dark by then.
20130218_30D_IMG_0040 by mellephants, on Flickr
I just snuck a ring terminal under the OE battery strap, and tucked the 4 AWG into factory wiring channels.
20130218_30D_IMG_0041 by mellephants, on Flickr
20130218_30D_IMG_0042 by mellephants, on Flickr
I still haven't attached it very well, but it doesn't move around too much. I will probably 3M doublesided tape or velcro it to the fuse box lid, unless I think of some better place to hide it. At least it isn't translucent or bright red or anything.
20130218_30D_IMG_0045 by mellephants, on Flickr
20130218_30D_IMG_0052 by mellephants, on Flickr
To get the wiring into the car, I went through the fender/doorsill, then under the carpet on the driver's side. This is the only place the wire is visible, which I am not totally happy with, but it didn't require any modifications or cutting of anything. Instead of punching a hole in the factory grommet for this hole, I just removed it. I will source a replacement grommet to cut a hole in, so the original can be installed if the wire is removed later on.
20130218_30D_IMG_0044 by mellephants, on Flickr
SCT PRP FTMFW!
mellephants is offline
