Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - focus is dead:(
Thread: focus is dead:(
Old 02-19-2013, 01:58 PM   #20
swagfocuswagon
swagfocuswagon's Avatar
Fan#: 103591
What I Drive: '00 Focus wagon, 96 Cutlass Supreme
FF Reputation: 1 swagfocuswagon Good Standing Member
Well, unless GM changed the location of the alternator (up top near the firewall), you'll have fun changing the alternator. The process might seem unnerving, but that's how you do it- unbolt the motor strut bars, put it in reverse, and have an assistant put a block of wood between the firewall and the engine. You have to do it though.
GMs and Fords- as well as all manufacturers- have their sillinesses and advantages. GM will keep parts forever, and use them in everything. It was well into the 90's- maybe into the 00's before GM quit using that same old MAP sensor they've had since the 80's. The starters- well those are the same, although the gear box might be rotated with the motor.
I hate the 2.8 60 deg GM V6. That's what you have with a little more stroke. If you ever have to remove the crankshaft pulley- you'll need to sacrifice a balancer puller. It will come off with the next one. I highly suggest sanding the crank snout so it won't kill a balancer puller.
There are some good things about GMs. For example, motor swaps are much easier. You want a 3.8? No problem. Everything will do it, and all GM FWDs have the same engine/trans bolt pattern. You can probably find a car model- Buick Regal maybe- with the engine you want, and all the wiring without much of an issue. Newer GMs might require some programming, but I doubt it. That's not GM's style. Everything is likely easy swap with a little research.
Ford silliness? Oh, they can't keep their hands off anything, and will change stuff for no good reason at all. I can't begin to add up how much engineering money was wasted on 2 piece spark plugs, and then how much more to design a removal tool for when those broke. Then of course, the warranty repairs as a result. Ford has no unified engine/trans bolt pattern like GM- and there's no sense not to do it.
^this. Thats why I love GM vehicles. They aren't built as well as a Ford but they are a shit tone easier to service. The Oldsmobile I had used a 3.1 (newer and improved 2.8 basically) and alternators on it and water pumps were simple as pie. Only thing that sucked was getting to the rear spark plugs but if you had the right tools for the job you could fix them in under 15 minutes I swear... Also parts for GM's are super cheap and you can get them just about anywhere.
I hate the word swag.
swagfocuswagon is offline
