Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Window question.
Old 02-19-2013, 03:50 AM   #1
Plymchris
Fan#: 110100
What I Drive: '07 Estate
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 1 Plymchris Good Standing Member
Window question.
Hi there, I have a MKII estate. The rubber seal at the bottom of the electric window (both passenger and driver) has a built up quite a garden of moss, even though I have done a fairly good job of cleaning this all up I have a problem in the fact that when the windows wind down the seal does not wipe the water off the windows so not only does it mean that I cannot clear them easily when the are wet but I am also worried that this means water will be able ot easily run down inside the door.
Any suggestions? Also wat is the technical name for this component should I have to replace it? Whenever I search for window seals I get the ones that run around the edge but not the bit at the bottom.
Many thanks for any help.
Plymchris is offline
