Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 01 zx3 manual trans won't go into gear
Old 02-18-2013, 08:30 PM   #2
ManiacalZX3
ManiacalZX3's Avatar
Fan#: 6111
What I Drive: 2001 White ZX3, 1987 Mustang GT
Points 720, Level 14
Points: 720, Level: 14 Points: 720, Level: 14 Points: 720, Level: 14
Level Up 20% Completed
FF Reputation: 2 ManiacalZX3 Good Standing Member
I had this on my 1991 escort. What I found was that the needle bearings in the pilot bearing came out and caused the input shaft to get seized into the pilot bearing in the crankshaft. So the clutch felt normal, I even could see the slave cylinder move normally against the clutch. I could shift with the engine off, if I was already moving I could shift gears by matching rpms. Now Im not saying its the bearing for sure but I would bet money on something with the clutch or related part. Sadly Im sure you have to pull trans and engine apart to look inside.
ManiacalZX3 is offline
