Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - zx2 head on a zx3 engine
Old 02-18-2013, 02:12 PM   #10
Energyblue98
Energyblue98's Avatar
Fan#: 99294
What I Drive: 1998 Turbo ZX2
Points 804, Level 15
Points: 804, Level: 15 Points: 804, Level: 15 Points: 804, Level: 15
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 1 Energyblue98 Good Standing Member
Originally Posted by 1turbofocus View Post
Yes you can swap the heads but the ZX3 head is just as good , your zx3 should go to 6250 just like the zx2 does
For better performance add a SVT header , intake , TB and a tune and you will see about a 20% gain in performance
Tom
uhhh zx2 goes to around 7k... definatly not 6250?
but regardless if it revs more or not, you will need to get a vct delete if you want to use a zx2 head, and the vct deletes for the zx2 are hard to find... unless you can figure a way to wire in the use of the vct into your engine.
the vct is variable cam timing and it's on the exhaust cam (unlike the intake cam on the svt engines).
Energyblue98 is offline
