Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec Powered MGB Build Thread
Old 02-18-2013, 10:39 AM   #89
Mustangsix
Mustangsix's Avatar
Fan#: 106702
What I Drive: 32 Ford, 73 MGB GT
Points 1,797, Level 24
Points: 1,797, Level: 24 Points: 1,797, Level: 24 Points: 1,797, Level: 24
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
FF Reputation: 1 Mustangsix Good Standing Member
We're mixing and matching a lot of parts, but it's not just a bolt-together. The input shaft of the transmission has to be turned down from .662" to .590" and shortened by about .380".
We're using the Escort flywheel because its a lot lighter than the Zetec flywheel (about 6 lbs less) and the Mustang clutch will bolt on. We're adding a trigger wheel to the front of the engine for the EDIS crank sensor.
Still have to make bushings for the bellhousing dowels to properly locate the bell and we still have to decide whether to mod the block or mod the bell for the top two bolts.
Mustangsix is offline
