Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Stereo questions
Old 02-18-2013, 08:07 AM   #22
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
Originally Posted by adam6976 View Post
If your car has a factory amp you shoud be able to tie into to it to run the new one you should run bigger pos wire from bat an ground but for signal in place of rca the factory may use wireing that you could connect an use the high input on you amp looks like lil sqa plug with sspeaker wire in place of rca an should be able to use remot lead off of factory amp to . just a thought mine had no sync an other stuff so all factory junk in mine is gone .
First I gotta is huh?
Second, Actually it looks pretty simple. The hardest part is just running the power cable from front to back. I did this type of install on a older ford Taurus that had a stock sub woofer. I just tapped into the sub woofer's wires. I am keeping everything else stock just need that extra bass. Fyi my amp has the LOC built into it.
HoneyBadger is offline
