Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec Powered MGB Build Thread
Old 02-17-2013, 10:09 PM   #88
79mgb
79mgb's Avatar
Fan#: 105006
What I Drive: 1979 MG MGB
Points 3,745, Level 38
Points: 3,745, Level: 38 Points: 3,745, Level: 38 Points: 3,745, Level: 38
Level Up 64% Completed
FF Reputation: 3 79mgb Good Standing Member
Buy-Sell-Trade Rating: (4)
Here's the other update I promised. If this sounds a little vague or spaced out it's because I'm watching Walking Dead.
I'm planning on using this 1992 Escort (1.9L) flywheel. It's used but in pretty good condition. It had a light surface rust but cleaned up well with a wire brush. The Mustang flywheel bolt holes are 10mm while the Zetec bolts are 11mm. I'll just need to open up the holes to fit some Zetec Flywheel bolts.
We'll be using a release bearing from a 2001 Camaro LS1.
Here's a T-5 from a 1996 Mustang (3.8L V6):
And here it is as we mount it to a bell housing from a 1992 Mustang (2.3L):
Now I need to look at getting a clutch kit, starter, and some hardware for the flywheel and pressure plate.
79mgb is offline
