Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Stereo questions
Old 02-17-2013, 05:33 PM   #21
adam6976's Avatar
Fan#: 108265
What I Drive: 2002 white se
FF Reputation: 1 adam6976 Good Standing Member
If your car has a factory amp you shoud be able to tie into to it to run the new one you should run bigger pos wire from bat an ground but for signal in place of rca the factory may use wireing that you could connect an use the high input on you amp looks like lil sqa plug with sspeaker wire in place of rca an should be able to use remot lead off of factory amp to . just a thought mine had no sync an other stuff so all factory junk in mine is gone .
adam6976 is offline
