Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Removing OEM gauge cluster: how to
Old 02-17-2013, 01:08 PM   #1
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,290, Level 51
Points: 6,290, Level: 51 Points: 6,290, Level: 51 Points: 6,290, Level: 51
Level Up 70% Completed
FF Reputation: 9 Deftmetal Good Standing Member
Buy-Sell-Trade Rating: (3)
These pictures were taken on re assembly.
1: first put the steering wheel in the downward rearmost position.
2: grab the middle plastic piece and slide it towards rear of vehicle
3: the fabric piece clips into steering wheel, it pulls up easily.
4: there are 2 torque screws that hold the gauges in. One below each of the big gauges. Remove them.
5: the gauges slide out. They are in tight but with the 2 screws removed there is nothing else holding it in. Angle the gauges out passenger side first until there is resistance from the wire.
6: The electrical connector now needs to be removed. The connector has a tab that needs to be depressed in the centre.
This allows the retainer to be flipped (like a light switch)
This is locked position
Open position
7: the assembly can now be slid out towards passenger side with wiper arm in down position.
Disassembly of the gauge cluster.
There are 4 clips on top, 4 clips on bottom.
Outer piece comes off
There is nothing holding the rest together
Rally Revolution #14
Josh
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
