Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - engine system fault - no codes
Old 02-17-2013, 12:43 PM   #1
Fan#: 109739
What I Drive: 2001, blue, focus
FF Reputation: 1 lucas121121 Good Standing Member
Hi all.
Iv recently just purchased a focus 1.8 tdci zetec 56 reg.
Unfortunately it has a engine system fault, is in limp mode and has no warning lights (apart from the engine system fault.)
I got the AA out and they found no fault codes and were clueless to what was wrong.
I changed the fuel filter as it was very low on fuel when i bought it and was unsure how long it had been siting not running, this did not work though. My friend says it probably just needs to be run a bit because it may have been sitting around not running for a while, i cant see that putting it into limp mode though.
Just asking if you guys would have any idea what it could be. Im going to try and get to the turbo today, see if any pipes are cracked or if the turbine is ratterling.
Also, there is a rattle in the transmission when the clutch is engaged, from doing some online research it sounds like the fly wheel needs replacing, would this cause an engine system fault and put it into limp mode?
lucas121121 is offline
