Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012+ Zetec S Body Kit
Old 02-16-2013, 11:44 PM   #54
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,333, Level 72
Points: 12,333, Level: 72 Points: 12,333, Level: 72 Points: 12,333, Level: 72
Level Up 71% Completed
Forum Activity 5%
Buy-Sell-Trade Rating: (3)
Originally Posted by mishka View Post
also looking at this picture again, the sides (distance between the wheels) is different - shorter on the the sedan. Yes I see that the rear on the sedan is longer too. I guess the sides and the rear are both different.
You are suffering from optical confusion. The sedan, hatch and euro only estate all share the exact same 104.3" wheel base (that is the distance between the center of the front wheel and the center of the rear wheel when looking at those pictures. The sedan is 6.9" longer over all, all of this behind the rear wheels.
The side skirts are identical between the sedan and the hatch, and only one or two clips needed to be rearranged to fit the ST side skirts on a sedan.
Originally Posted by Chaos09 View Post
There has been ST (hatch only) side skirts fitted on the sedan. They are the same on the sides.
Technically they fit perfectly, but Twenty did have to add and or move a couple of clips to make them attach properly. That was the only technical difference between the physical ST skirts and the normal ones.
suss6052 is online now
