Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - driver door handle
Old 02-16-2013, 09:58 PM   #7
samtanamoss
Fan#: 109439
What I Drive: 2012 sonic blue S
FF Reputation: 1 samtanamoss Good Standing Member
Originally Posted by erka123 View Post
basically when i press the fob the sound is like a schhhump noise same as when i lock it.
i have to press it 2 times to open other 3 doors, 1 time to lock and then again to double lock and indicators flash 2 times to indicate double locked,on the inside of the car the little lock indicator ( where pull door open pull lever is shows the car is open but have to pull hadle 2 times, i only have to pull 2 times from the car been locked, once the door has been opened and closed ( unlock open door close it then open it again i only have to pull 1 time but if i lock it up again then its 2 pulls to open
It sounds like it is not unlocking all the way on the inside. You said it used to work correctly right? Try switching it out with one of the other doors that works correctly to help isolate if it is the actuator or the relay or an electrical problem if you haven't already.
samtanamoss is offline
