Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.0 Duratec Clutch Torques
Old 02-16-2013, 10:23 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,073, Level 100
Points: 33,073, Level: 100 Points: 33,073, Level: 100 Points: 33,073, Level: 100
Forum Activity 71%
Activity: 71% Activity: 71% Activity: 71%
Trans to engine: 35 ft-lbs
Trans mount bracket bolts: 59 ft-lbs
Trans mount nuts: 35 ft-lbs
Trans mount center bolt: 98 ft-lbs
Slave cylinder bolts: 89 in-lbs.
Pressure plate to flywheel bolts: 21 ft-lbs (I suggest tightening these in 2 steps and across from each other)
Flywheel bolts: Procedure- Tighten bolts across from each other like you would wheel lug nuts.
Step 1: 37 ft-lbs
Step 2: 50 ft-lbs
Step 3: 83 ft-lbs
Flywheel to engine bolts MUST be replaced when the flywheel is removed. Failure to do so will come back to get you. Ask around, it's happened to several people on here.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
