Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - driver door handle
Old 02-16-2013, 08:52 AM   #5
samtanamoss
Fan#: 109439
What I Drive: 2012 sonic blue S
FF Reputation: 1 samtanamoss Good Standing Member
Originally Posted by erka123 View Post
yeah, cleaned all parts,it used to do it with the original too where i had to pull the handle twice when i unlocked the car and the same again all other doors were fine ( only had to pull handle once like now) it is only driver door this happens to, got me puzzled as i had a year 2000 one and never had this
If you cleaned it and it still has this problem, most likely it is an electrical problem. If you can see a door lock indicator, try unlocking the door and observing if the indicator is showing fully unlocked or if it is only partially unlocked. If you cannot see the indicator, listen very closely. If it is only your driver door then you have either a relay problem or a wiring problem. What kind of sound does it make vs. the other doors when they unlock? Does it fully indicate that you unlocked it the first time? Does it completely indicate that it is unlocked after you pull the handle?
samtanamoss is offline
