Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need a diagram or pic. focus is dead
Old 02-15-2013, 06:15 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,454, Level 100
Points: 32,454, Level: 100 Points: 32,454, Level: 100 Points: 32,454, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
Man, I don't like the carb cleaner trick anyway. Too much risk and little reward, the same goes for starting fluid.
Is your VECI sticker still there? That gives a vacuum schematic. You lost a big one if you didn't crack the intake manifold. The only 2 big ones are the PCV and the brake booster line. Trace the brake booster line down from the booster back to the engine.
You're turboed right? You probably don't have a PCV. I bet it is capped off at the port, and if memory serves me correctly, someone said that port was just behind the TB. The PCV itself is probably just a simple hose turned down.
Did you check the air intake to see if it came loose? That will do something similar to what you're describing. Lack of a decent idle might be what is upsetting the power brakes. The engine has to be running, and running at enough rpm for that to feel right.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
