Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - stock alt output?
Old 02-15-2013, 02:07 AM   #11
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,672, Level 23
Points: 1,672, Level: 23 Points: 1,672, Level: 23 Points: 1,672, Level: 23
Level Up 72% Completed
FF Reputation: 1 popwarhomie Good Standing Member
Originally Posted by crice8 View Post
do you have any car audio batteries or just the stock one?
I have two amps, about 1400rms total and with only one shuirken bt-20 I had very little voltage drop. I just recieved a bt45 also that im going to add in and I expect almost no voltage drop.
Yes stock in front and a 55 AH in trunk right now. Drop to 13.5. But I have 2 102AH that will be going in the trunk for next setup.
I was hoping the stocker was 110 amp alt. That way it seems I was getting so much more with a 270 amp HO alt.. But if stocker is 150 then im only gaining 120 amps.
Kinda considering only doing a 2200 rms setup now and stick with a 200 amp alt and single 100AH battery.
But was planning on 4000 rms, 270 amp alt, and 2 102AH in trunk.
10 Coupe 5sp
Pioneer 80prs/2 Tantric SHD 21"s WALLED/5 90AH batteries/DC power 270XP Alt/Taramps T20.2kw/DSP3000/DSP1600/TS800x4/4 Crescendo UN-10"s/2 FT1 tweets
Projector retrofit with 50 watt morimoto.
popwarhomie is offline
