Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - hey yall, help please
Old 02-15-2013, 12:43 AM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,397, Level 29
Points: 2,397, Level: 29 Points: 2,397, Level: 29 Points: 2,397, Level: 29
Level Up 65% Completed
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
Buy-Sell-Trade Rating: (3)
A more detailed description with possible causes:
P0171 - System too Lean (Bank 1)
The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
Possible causes for lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
BC_ZX3 is offline
