Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012+ Mid Wings
Thread: 2012+ Mid Wings
Old 02-14-2013, 12:20 PM   #130
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by ShogunSamurai2005 View Post
I had mine put on the other day and the next day it was found on the ground! GRRRR!!! Ill be needing to put stronger thicker 3M tape on it.
Surface prep and compression are important during the initial mounting. Too cold is also an issue.
Even though it was 42F when I mounted mine, I left the wing and rear of the car in direct sunlight for 3hrs or so. Surface was very warm to the touch, wing was more flexible, tape was pliable.
After mounting, I used painters tape to maintain compression at 3 points across the middle and at both edges, then pulled the car into the garage to let the tape cool and cure. No issues whatsoever in the week since I mounted the wing. Temps have ranged from 0's-50's F, rain and snow and wind and salt.....
We'll see when it heats up if I have adhesion issues, but it is already fully cured so I doubt I will have problems.
Sonic's Mk3 Crew #11
Hatch Nation#163
TiStick is offline
