Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MK3 Headlight Adjust
Old 02-13-2013, 03:26 PM   #6
wilsonfocus86's Avatar
Fan#: 23099
What I Drive: 14 Fusion 2.0
FF Reputation: 3 wilsonfocus86 Good Standing Member
Originally Posted by scada View Post
Anyone know how to adjust the headlights in a MK3? I had a headlight replaced and now one is higher than the other.
I am at work and it is dark out. Figured I'd ask so when I go look I can fix it quick.
Originally Posted by jdetzel View Post
I have and still did not see it.
I figured I would stop by the dealer sometime and ask someone to show me.
Or maybe someone here who knows will post a pic with a BIG RED ARROW to point it out.
It is in the manual and it tells you to use a Number 2 Phillips screw driver (+). ON the back of the headlight housing there is a small vertical hole in which the screwdriver goes into and turns a plastic cog basically that heightens or lowers the beam up or down.
"If in doubt.. Flat out." - Colin McRae
wilsonfocus86 is offline
